parking brake removal question
xkotyx
Solid Axle Swap
Waynesboro, VA
is it hard to replace the parking brake system? mine is going bad, and is really noticable since i replaced the rear brakes. it almost constantly has a drag on it. tryed pb blasing everything, and loosening it but no help. :annoyed:
The biggest problem with the p-brake is the cables seize from rust.
If both brakes are dragging, check the front cable. If only one is dragging, check that rear cable from the split to the wheel.
If you are going to replace the Park brake, save time and CUT the cable(s). You will likely find one or more of the cables frozen (rusted). There are three cables.
If you are going to repair, find out which cable is frozen, cut it out, and replace it.
it just feels like the drivers side is dragging. ill have to play around with it sometime when i get a chance. been raining a few days in a row here.
