Painting my griile
BOL
chino valley Az
So I am going to paint my chrome grille black. How do I do it so the paint sticks? I tried it before and the paint keeps peeling off.
i've never tried to paint my grille, but i majored in industrial design(product design) in college and we had to actually make scale models of whatever it was we were designing at the time. soooooo, i have alot of experience painting all sorts of materials with all different types of paint.
my advice would be to get some really fine sandpaper and sand every square inch that is gonna be painted. not too hard, just scrape it up a little bit so the paint has somethin to grip to.
then wipe down everywhere you sanded and get all the dust and dirt off.
next start painting. i'd do between 2 and 4 thin coats. make sure you paint evenly and keep the paint can the same distance away from the grille as you paint.
i dont know what your grille is made off, but i'd get a paint that is made for that certain material. (i.e. plastic paint for plastic, metal paint for metal)
i'd buy the most expensive spray paint you can find, you really get what you pay for with spray paints. i used expensive paint on a shovel i designed and the paint is still on there even after 2 years of use. but just know, it's spray paint, one day it's gonna come off.
it's hard to explain all this on a post, it'd be easier to show you, but of course thats not possible.
hope this helps.
I painted the grill off of my 08, its the plastic chrome one. I sanded it down with a high grit sandpaper and then gave it 4 coats of black primer followed by 7 coats of flat black. just remember prep is the most important thing when it comes to painting. And as far as the coats go make them light and even or else you will end up with globs and a uneven finish. And I would say you might be able to use the Krylon plastic spray with out having to prime it but I have never tried it. So basicly +1 on what 88_Eddie said.
if you score the crome where it raps around with a razor blade, you can peel it up and off i used vise grips so i didnt cut myself and then i sand the plastic down and shot it my body color
I cleaned mine up with scotch bright, then washed it with auto soap and water rinsed well.
Once dry sprayed on two coats of Adhesion Promoter from DuPont, then sprayed on Black DuPont Paint.
Stick to teh same manufacturer of products and all should be well.:icon_cheers:
