paceserrer header
Str8sixfan
Anyone get one of these to work on the later years? I want to say they list them as working only up to the 1991 model. I have a 97 and am redoing my exhaust soon.
Your stock 2.3 header flows very well and does a good job but if you feel you need a new one the pacesetter is a decent choice.They are smaller tubes so you don't loose all your bottom end.If you are looking for more top end,go with a Shoenfeld header with bigger tubes.you will have to weld on a bung for 02 and EGR but easily done.
I found elsewhere a less than stellar rep for pacesetter. Will probably stick with the stock unit as it does look designed fine. Have a hi flow cat ready to go on, and thinking a spin tech muffler...stock cat is clogged
