P0457 (broken Y connector)
mm24
CT
My truck recently had the fuel pump replaced, and about a month later the "check fuel cap" light (code P0457) came on. It appears that the Y connector for the fuel tank vent valve to the EVAP canister is broken on one side. My guess is that it was inadvertently snapped when the gas tank was removed to access the fuel pump. Any suggestions where I can order this part? Thanks!
You are going to need to find a friendly parts guy at the Ford dealer. If he finds it, and most likely can't get it, make sure to write down the Ford part number he has and thank him. Then you can plug that number in google and see what comes up. There may be one on ebay or somewhere else.
Thank you...will give it shot!
