juice90
- Jul 12, 2014
Ok, so earlier in the week I posted my truck was giving me issue, but no engine check light. Curious me, plugged in a code reader today and low and behold, P0420 is present. ( check engine light bulb prob burned out. )
No other codes are present. Decided to check the freeze frame data and it said:
STFT B1% -1.5
LTFT B1 % -2.3
STFT B2% 3.1
LTFT B2% -3.0
So for shits n giggles, I decided to do a live data on the way home. Everything appeared normal, I think, they way I understand it anyways, until I had to stop for a train.
While I was sitting there, then engine began to sputter and when I looked, I had o2 B1 v stuck at 0.200 and STFT B1 S1% stuck at -23.3
Those numbers stayed there for about 30 to 40 seconds as I tried to drive off, poor acceleration and sputtering. Then, the sputtering quit, and away I go, and those two numbers went back to what ever they had been up to that point and didn't do it again all the way home.
Would I be correct in assuming, based on the info, that the up stream o2 sensor has gone bad? Truck has 170000 kms and I assume the sensors have never been changed, and I see for recommends around 100000 km before changing.
98 mazda B4000 4x4 auto 4.0 V6
STFT B1% -1.5
LTFT B1 % -2.3
STFT B2% 3.1
LTFT B2% -3.0
