P0297 OBD Code
MastuhWaffles
11/2014 OTOTM Winner
OTOTM Winner
TRS Banner 2012-2015
Texas
I need more sleep.
I have an OBD 2 scanner I was checking for fault codes and P0297 came up and I looked it up and it says its an overspeed condition? Am I driving to fast or something? Any help with this, and if it's a serious problem or not... And how to fix it.
I've also got a U1900 Network code and B1352 Body code..?
Everything seems to work fine....
Oh and I did some more digging into the P0297 code and found out that it's because I went over 95mph, I hit 97mph last week. I don't think anythings messed up because there no check engine light or anything and it runs just fine. As for the other codes I can't really find out what they are other than a small description.
I just hope my trucks not broken. D:
I did some looking up on the B1352 and U1900 code, and it seems that the B1352 code is for when you have the key in and the door open the chime plays, and my chime still works so I guess it might be that I have all those extra lights wired up and its messing with it. Not really concerned about it I can live without the buzzer.
U1900 is still in the dark I can't figure out what it is!
I should try clearing them and maybe lay off the dirt racing.....
That's not good. Not really sure what is doing it, but I have the feeling the extra lights I added on might have something to do with it...
U1900 is a worthless code. To do anything with it you need to know which module it was in, but for the most part it is worthless and useless. All it really means is that one module stopped hearing from another one. They can set for any number of reasons, including low battery voltage or unplugging the wrong thing with the key on.
Clear it, forget it, and get on with life.
The P0297 only sets if you hit the speed limiter. Slow the F down.
The B1352 I would only worry about if you actually have an issue with the door chime.
Lol, well no one believed my ranger would get past 80. So I said watch this.
The only issue with the chime would be if it was stuck on forever. Which happened in my 88 F-150 and I just unplugged the fuse.
"The P0297 only sets if you hit the speed limiter. Slow the F down."
This should be in my signature rofl.
So put it in your sig.
:D
I actually found out that I hit 102 mph, my speedometer said 97 but its an error due to my tires so i was actually doing 102.
