P0174(or P0171) means the computers calculations of the fuel to be added is low after the air/fuel mix has been burned.
Computer gets MAF(mass air flow) data and then calculates the fuel that needs to be added via the injectors to get the 14.7:1 Air:Fuel ratio needed in gasoline engines.
That mix is burned and then O2 sensor tells computer the Oxygen level in the exhaust.
Too little Oxygen means Rich, too much Oxygen means Lean.
If Lean computer adds more fuel until Oxygen level in exhaust is correct.
This takes milliseconds so engine is never really running Lean.
But computer lets driver know about the calculation errors by setting a code or codes.
If all the air coming into the engine is not going thru the MAF sensor then computer's calculation would be off, this is why vacuum leaks can set these Lean codes.
Water in vacuum lines wouldn't do it but will cause other issues, depending on where you live and local temp and humidity condensation in the PCV hoses can be normal.
Engine will be sucking in the air with water vapor(humidity) in it and so will the PCV system via the Vent hose.
When engine is shut off that water vapor will condense on parts that cool off first, like hoses, and if you remove those hoses you would see liquid water.
Like the water that forms on the outside of a cold beer glass on a hot day
There are 2 hoses for the DPFE sensor that go to the exhaust/EGR system, water in these hoses can ruin the DPFE sensor.
When gasoline(Hydrocarbon) is burned in the presence of air(oxygen) a normal by product is H2O(water), this is why exhaust systems rust from the inside out and why you often see water dripping from tail pipes.
Higher humidity would of course produce more water in the exhaust.
Having just one bank showing Lean code would tend to point to either failing O2 sensor on that bank of the engine or a lower intake vacuum leak on that side.
An exhaust leak on that side can suck in air(oxygen) making for a False lean on that O2 sensor.
If both banks get lean code then MAF sensor or upper intake vacuum leak would be indicated.
Both O2 sensors failing would be a long shot.
Clean MAF sensor.
After engine is warmed up and idling, unplug IAC Valve, idle should drop down to 500rpm or engine may even stall, either is good it means no vacuum leaks, if idle stays high then there is a leak.
