P0171
brwntom
Firefighter
Northwest Indiana
Its a 2.5 1998 what causes this code? What could i try to fix it?
Tom :icon_confused:
Straight from chilton manual.
Trouble Code Conditions:
Engine started, engine running at cruise speed for 3 to 4 minutes, and the PCM detected the Bank 1 Adaptive Fuel Control System reached its rich correction limit (a lean A/F condition).
Possible Causes:
Air leaks after the MAF sensor, or leaks in the PCV system
Exhaust leaks before or near where the HO2S is mounted
Fuel injector(s) restricted or not supplying enough fuel
Fuel pump not supplying enough fuel during high fuel demand conditions
Leaking EGR gasket, or leaking EGR valve diaphragm
MAF sensor dirty (causes PCM to underestimate airflow)
Vehicle running out of fuel
That about says it.
