macd7919
- Dec 1, 2009
- Automatic
Hi Guys,
I've been researching this issue and have done the common things but still have this check engine light coming back and am sick of dealing with it. The truck is a 1997 Ranger 4.0L XLT with a manual transmission.
Occasionally it will go off on it's own (last night it went off for example) but it's generally on 99% of the time. Very rarely does it shut off by itself. I also have been getting poor gas mileage this whole time, in the neighborhood of 11-13mpg around town, maybe 15mpg on the highway.
So far I have:
Replaced the MAF with new
Checked for vacuum leaks thoroughly and manifold leaks
Replaced the PCV
Replaced the DPFE
I checked vacuum at the EGR and it seems to be getting a good pull, outside of directly related things I have replaced the filter and also changed all the plugs. Using the scanner I was able to get the following information:
Fuel Sys 1: CL
Fuel Sys 2: NA
Calc Load %: 68.2
Ect (F): 165
STFT B1 %: 6.2
LTFT B1 %: -5.4%
STFT B2 %: 3.1
LTFT B2 %: -5.4
RPM: 1649
Speed: 16
Codes are: P0171 and P1443
Any help would be appreciated, is it possible this is an O2 Sensor issue?
Off topic but the truck leaks fuel from the filler when I fill the tank, not tons of fuel but it definitely drips while the gas is being put in, doesn't drip while driving or once fuel so I'm assuming the filler neck needs to be replaced/patched at some point. Not sure if this would cause a vacuum condition or something but putting it out there so the experts have all the info. Thanks for any help guys!
So far I have:
Replaced the PCV
Replaced the DPFE
Fuel Sys 1: CL
Fuel Sys 2: NA
Calc Load %: 68.2
Ect (F): 165
STFT B1 %: 6.2
LTFT B1 %: -5.4%
STFT B2 %: 3.1
LTFT B2 %: -5.4
RPM: 1649
Speed: 16
