PNW Ranger
My Ranger is slow, that's for sure. According to my mechanic, the advantage of the 3.0 L V6 is that it will last forever.The 3.0 is slow enough as is, it would be awful with bigger tires.
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I've got a reg cab Ranger (which weighs about 500lbs less) with a 3.0. and a 4:10. I installed a KI&N filter, an E fan, dual exhausts, as well as a number of smaller tweaks. One was to tighten the accelerator cable. Another was all synthetic oil. I think I've got 30 inch tires. The net result is a 0-60 of 9.1 seconds. That might be slow for some of you. It won't spin the tires. I would like a little faster, but it's not that bad.My Ranger is slow, that's for sure. According to my mechanic, the advantage of the 3.0 L V6 is that it will last forever.
You mean you can spin the tires with your 3.0?Your truck must be an auto with all the not able to spin the tires talk..
I'd suggest getting rid of the k&n filter though.. many many "studies" have shown that they let a meaningful amount more dust unto the motor when compared to a paper filter.. even when properly oiled. Another thing is.. when an oil filter gets dirty enough.. it starts letting even MORE stuff into the motor.. compared to a paper filter.. when they get that dirty they don't even let AIR through.. let alone contaminants.
Really.. do some deep digging on k&n filters. You'll be surprised at how poorly they filter. The dustier the environment.. the worse is is.. and the saltbelt suuucks for dust. They use so much salt&calcium on the roads up here.. when the roads are dry.. traffic will kick up an incredible amount of dust. Allllmost as bad as driving down a bone dry dirt road... literally..
Dust from dirt is bad enough.. but you DEFINITELY don't want to be sucking up dust that's corrosive.
If you have seen many many studies that show K&N filters let a meaningful amount of dust through, the studies are either flawed or they don't know what meaningful means.I'd suggest getting rid of the k&n filter though.. many many "studies" have shown that they let a meaningful amount more dust unto the motor when compared to a paper filter.. even when properly oiled. Another thing is.. when an oil filter gets dirty enough.. it starts letting even MORE stuff into the motor.. compared to a paper filter.. when they get that dirty they don't even let AIR through.. let alone contaminants.
Yes an auto. I had hoped for a decent reg cab with stick and also 4WD, but gave up searching after a couple years. A couple extra HP would have been nice, also manual, but I'm content to settle for a 3.0 which runs right and tight. Old Rangers are beginning to get rare. The Ford dealer told me that they are still very popular and that they stay on the lot for only a day or two before they are sold.Your truck must be an auto with all the not able to spin the tires talk..
I have a total of almost 500K miles on two different Rangers with K&N fair filters on them and there was absolutely no sign the filters let a meaningful amount of dust through. I had the oil analyzed on my 89 STX each oil change and there was no indication of dust getting into the engine. With almost 200K miles on it when I sold it to a co-worker, it used no more oil than it did when I bought it new. My current 02 FX4 is approaching 300K miles and it too uses no more oil than it did when I bought it new. So, if K&N filters pass dust, it certainly is not meaningful or the rings would be worn and those engines would use more oil.
I typically spend 4 weeks every year off-road in dusty conditions. I travel with groups and usually eat a lot of dust that is kicked up. When I clean the filter after the trips, it is caked up heavily with dust on the front side. The back side is as clean as the last time I cleaned it with that pinkish color still showing. I also wipe the inside of the intake tube with a white cloth and there has not been any sign of dust.
If you want to trust those studies, that is up to you. I prefer to trust the 500K miles of experience I have with K&N air filters. I am not trying to sell you on them, I just don't like bad advice being advertised. Of course, K&N air filters must be cleaned and oiled properly for them to work right.
I wouldn't call that an advantage, why would you want to drive something that slow for that long?
You may have misunderstood my post. I am not talking about modifying the intake system. I am talking about using a drop in K&N filter. Or are you saying you prefer to use only Motorcraft or Autolite filters?I will trust the guys that designed the intake system in the first place.
They have dusted many an engine, especially boosted.
I have never used the aftermarket cold air intake systems. Actually, they tend to be hot air intake systems.
Now about tires. I ran into this thread because checking out rim sizes and backspacing on 2000 Ranger. This Ranger has been all over the country passing through family members. 2000 4X4 with 16" aluminum rims that are ate up from salt. It has 3.0 with 5 speed manual, 4.10 8.8 rear end. While I had the truck, I replaced the original Firestones, while replacing Firestones was free, with 275 75 16 BFG. It is a short bed and I was more worried about stopping instead of going with a load of sand in the back. I don't think the 3.0 will have trouble with 30" tires. The 7.5 rear end might not hold up with torque required if he goes much bigger than 30".
