Overdrive Lock-Out Switch Not Working?
IndianaRanger
SE Indiana
Guys,
My overdrive lock-out switch located on the end of the auto's shifter handle, column mounted, has stopped working. The transmission still operates as it should, but the switch will not lock-out the overdrive. The lamp on the instrument cluster does not illuminate either.
Is there a quick "fix" for this? I mean, is there a fuse that could be blown that would cause this to happen?
Thanks,
Tom
Most likely the shifter wire is broken.
