swynx
Woke up late for my orientation. Started the truck, it started hard, took a 5 minute shower went out windows weren't defrosted yet. Scraped the window and took off. Got about a mile away to the hill and noticed the temp guard all the way on red hot. Got 2 pings from the engine before I got it to the top shut it off. Called the girl friend. Pulled off the radiator cap what little bit of radiator fluid was in there boiled out. That's when I knew it froze. Was 5 degrees last night. 2 minutes later started it. It ran fine and was at normal temp. Got a ride to my orientation.
Had her pick up antifreeze for both rigs. THe car had slush in it. Put some antifreeze in the truck started right up drove it home the temp change only came off dead cold once, it spiked to hot then back down to cold. Noticed I had no air. After letting it Austin the drive way while squeezing hoses and fiddling with the air a puff of steam came out from under he hood and the air started working. Hot as it ussually is and the temp change is now working
Being a 300k mile engine I'm worried about it. I'm assuming everything was frozen in it (thermostat radiator the heater thing)
Oh and there isn't water in the oil
