Decker
- Apr 19, 2011
I've got an issue with my 94 Ranger 2.3 5spd. The truck never heats up according to the gauge (I know, it's inacurate). I went so far as to remove the clutch fan last night and ran it for 20 mins before it registered 1/3 up the gauge and had pressure and heat in both hoses. I stopped after that as I didn't want to overheat it.
I have read lots of threads here, but most indicate they do not get heat out of the heater, and I do. I've also read where it could be air in the cooling system, so I popped the cap to the first click and drove for 5 miles to burp it, that did not help.
I'm at a loss as to the problem with this truck.
I want to get it running out of closed loop mode so I can get better economy.
Symptoms:
Heat out of heater
No pressure in cooling system
Top radiator hose warm, but not HOT
Bottom radiator hose cool, but not cold
Cap removed after parking, I am able to stick my finger in the coolant. I'd say it's no more then 120 degrees most of the time.
Parts replaced due to failure or routine maintenance:
Plugs
Wires
Coolant
Air Filter
O2 Sensor (stock replacement)
Radiator cap (13 lb stock type, twice)
Thermostat (Failsafe brand, 192* stock temp)
Water temp sensor (the one in the heater hose)
Water temp switch (the one in the block below the oil pressure sensor)
EGR gasket (jacktard P.O. used a Dr. Pepper can as a block off, which blew through 1/2 of it)
Exhaust system from header back (No cat(its on order) -> flowmaster 40 -> nutin. 2" pipe)
Cleaned as part of routine maintenance:
Fuel system - 1 can of Seafoam in the tank
Cooling system - Backflushed with at home kit
Throttle body - cleaned with TB cleaner & towel
MAF - Disassembled and cleaned with MAF cleaner
Any ideas are helpful
Symptoms:
Heat out of heater
Plugs
Wires
Coolant
Air Filter
