I have been chasing a vibration, all suspension components i have replaced and got new tires w/ balance and have done u-joints as well. My vibration has significantly reduced however im stuck with this output shaft play, it is where the yoke goes into the transmission, i can wiggle it up and down, side to side, the seal started to leak and i noticed the play is slowly getting worse, there is also a tail housing leak at the section that sits on the trans mount. Any words of advice on this? Im thinking its a bushing in there or a bearing that has gone awry. I can also see bolts to take off the tail housing to the transmission if needed, its a 5r44E for an 06 3.0 ranger but no manual i have read offers help with how to do this or symptoms of it. Want to know if its possible to do this with-ought removing the tranny and if im on the right track if thinking a bushing or bearing. Thanks!
