srteach
- Aug 11, 2007
I have an idea of what might be wrong, but I want unbiased opinions.
The problem:
The throttle will not back down in most deceleration cases. When I release the throttle to decelerate, the throttle will most times stay at the last RPM speed (clutch in or out). i have to come to a complete stop and slap the throttle pedal before it drops to idle RPM. It then will idle at about 450RPM (book spec idle is 750 to 800 RPM).
On start, it will usually die unless I use the throttle to keep it running (warm or cold engine).
I believe that the IAC valve is not working properly. (IAC has been cleaned many times.) Am I right or wrong? Opinions? Other things to check?
The problem:
