C.O.RBVaddict
- Oct 9, 2017
- Automatic
Ordered a one piece shaft from a local yard for my '91 extended cab 4WD (4.0, A4LD,1354M, D35,8.8) and received what they claim is a '99 shaft.
Both yokes are the large 3" bolt pattern and it's 1-1.5" too long installed. My truck is stock height right now and at ride height the shaft only has roughly 1/4" of compression left in it, if that. Is there a possibility that they sent me the wrong shaft?
I called and they are pulling a shaft in another yard, from a '98 this time around. Won't know till Tuesday if that one is correct or not. Hoping that this doesn't just turn into an opened can or worms. And I REALLY don't want to end up with a silly long shaft stuffed through the back of my t-case.
Sent from my SM-S975L using Tapatalk
