Driver4r
- Mar 24, 2018
- Age
- 30
So I bought an 88 ranger to be a winter rig to keep my stuff salt free, and it's a 2wd std cab long box. 2.3 that was auto but converted to 5 speed.
It was running pretty good, except it had a faint rod knock at higher rpm. But I drove it all over. 1 morning heading to work i was pulling a hill and had the radio up, it felt like it had died, so I crested the top of the hill and turned down the radio, it was still running, but was way low on power and had to slip the clutch alot to get it to start moving, so I decided I would limp it the extra mile to my work. Well after making it 3/4 the mile left to work, the exhaust manifold had gotten hot enough to ignite the heat riser tube and lit all the wiring on fire... had a cooler of water so I extinguished it.. Well some time had passed then one day I finally patched the harness back together in attempt to get it running again.
After fixing it it would start and run for a few seconds, then die. So I cut the cat off. Still the same. Checked the timing belt and threw a new one in since I was there. Same thing. Changed fuel filters, same.
New fuel filter(rear filter deleted)
New map (old burnt up)
New timing belt
New wires (old burnt up)
New plugs
Swapped out injectors
*the fuel pressure tests good
*all injectors are triggered *noid lights*
*Moving the distributor doesn't help make it better or worse
*compression is good
*passed leakdown
*tps waveform is perfect
So it has been setting for awile again to get a clear head to mess with it again.
Is it possible the ecu failed and it's pulling it way retarted? Hence the glowing exhaust.
Or is there more things I can diagnose?
Sent from my SM-G930V using Tapatalk
New timing belt
New plugs
*passed leakdown
