Old BII, Newer Wheels
MarkB
Southern Ohio
88
Need some suggestions on 85 auto hub O.D vs. 97 Edge wheel I.D? The issue is the I.D. of the wheel is too small for the O.D of the hub. Can the I.D of the wheel be bored to fit the hub? if so, what is the easiest/best way to do this? What tools would I need. Thank you for any help!
Generally the wheel bore can be machined out by a machinist. If you talk to a local wheel finishing company they will probably be able to direct you accordingly. I wouldn't recommend doing it yourself (unless you know what your doing) because the center of the wheel can cause a vibration while driving if the wheel is off center.
