- Dec 16, 2008
- kansas
- 1996 and 2002
oh well, this is my last post in this thread.
haha do you know where liars go?
okay well unfortuntely i think i'll probably stick with the 8g amp kit, and i will get 16g for the amp -> sub and terminal cup -> voice coil
so i might want to look for about 35 volts if their 40v is 400w?
same place as ignorant people?![]()
i came back to this thread to help you get your problem resolved and then you call me a liar. how else do you expect me to take that comment?
bigger wire is more efficient. Bigger guage wire will have less resistance from start to end so less power is lost between your battery and amps
actually, the current is carried on the outside of the wire. many, many smaller wires bundled together will carry much more current more efficiently than fewer larger wires. just look at welding cables to verify this. only problem is welding cable can be pretty expensive to buy and would probably be overkill for speaker/amp wiring projects.
