ccrunner1
i decided to check my oil today it smells like gas. what does it mean.
You should change the oil. Since it's been 8 months and only 2700 miles, I'm assuming you do a lot of short trips. This explains the fuel smell. When you first start the truck, the computer makes it run rich until the engine warms up, a lot like a choke on a carb'ed vehicle. Some of that excess fuel ends up in the oil, diluting it. This is one of the reasons short trip driving is a lot harder on an engine than long, extended trips. With the amount of driving you do, I would just change the oil every 6 months regardless of mileage.
And I don't know what light you're referring to. Rangers don't have a "change oil" light.
That light means your oil is low, not needing to be changed.
No it's the oil level light, not the pressure. It usually turns on at 1.5 quarts low. I ran my 2.9 to the low oil light constanly, and added then, lazy man's dipstick+1. That's not the "change oil" light, it's the "change engine" light. By the time that light turns on, there's a good chance your engine is already toast.
No it's the oil level light, not the pressure. It usually turns on at 1.5 quarts low. I ran my 2.9 to the low oil light constanly, and added then, lazy man's dipstick![]()
Yea, the 08/09's are starting to have the change oil soon reminders,
