Well back befor the site mishap I swaped out a 4speed for a 5speed and was unsure of what fluid to use as I was unsure of what yr the trans came from
My truck is an 84 ranger 2.8 it had the 4speed when I got it. Well I came across a guy that had a 5speed trans and transfer case with the longer front shaft I would need. All he could tell me was that is was out of a late 80's maybe early 90's bronco. It looked just like my 4speed trans, so now that I got that info out.
I used a 75wt gear oil in the trans and ATF in the transfer case, but it has gottin cold here in now its really hard to shift the trans when its cold. As in right after I start-up and start driving, after I get few miles in everythings seems about normal so... does this trans maybe need the ATF and not gear oil ?
ok so what about the part where is will hardly shift into gear when its cold ?
