- Feb 19, 2008
- Age
- 65
- Camby, IN
- 4.0 V6
NO that is all wrong. The SECOND number is the viscosity when hot. So 5w-30 and 0w-30 are the same viscosity when hot and provide equal protection.
The first number refers to how much the oil thickens when cold. It is NOT a viscosity number. (a 5w-30 is NOT a "5 weight" when cold) Very simply, the higher the number, the more it thickens when cold. So a 0w-30 and 5w-30 are the same thing, except the 0w-30 won't thicken up as much in really cold temps.
exbass94 is right.
Actually, calling 0W 30 a multi-vis is a misnomer, since it has the same viscosity at 0C as it does at operating temp, while a straight 30 wt will have a whole range of viscosities, depending on what temp it is.
If it's cold where you are, or even if it gets below 60 at night, then run the 5W-30 or better yet 0W-30.
Your engine will thank you for it.
