oil pump seals
Can anyone tell me if there is a way to get just the seal and gasket for the the oil pump on my 1996 ranger 2.3l .its leaking oil around the the pump and the only way to get this is if i buy a new pump from the part stores. the pump is fine.. thanks Mike
You could purchase a gasket set that would contain all seals, and gaskets used in building the engine. You could cut a gasket from black gasket paper, thin stuff, that should work.
Don't know about the seal, but you might take the old one and look for a match at a parts store.
tom
