Ok..... I finally put an oil pressure gauge on Tonto and the results were not good.... At operating temp, I was only getting between 8-10psi at idle and the most I got while running throttle up was between 45-48psi....
How much of a pain is it to drop the pan on these things so I can replace it? How high does the motor need to come up? Can the tranny stay connected? Not really looking forward to this job but if it will help my lifter tick then it will ALL be worth it! Thanks for the help guys!
