robotzombies
- Jun 2, 2015
- Seattle, WA
- 2.9 V6
- Manual
- Total Lift
- 3"
- Tire Size
- 33"
Hi everyone,
I'm getting a little lifter tick in 1989 Bronco II with 2.9 engine. The truck sits for a while, so I'm assuming that oil is probably gravitating downward during the sitting time, and therefore top end is not being lubricated as it should be.
So I've got the Melling high volume oil pump and tube that I'm going to install, which will hopefully help. I have two questions that I can't find an answer to so far:
1. The Haynes manual has you take off a whole lot of parts like starter, air intake tube, fan shroud, etc, as well as removing the engine mounting bolts/jacking up the engine. Is this necessary? Or can I just drop the oil pan and have relatively decent access to the oil pump?
2. I also can't seem to find a good way to prime the pump. Again, Haynes says to fill the pump with oil and rotate the shaft, but it's not clear if they mean once it's installed or before you bolt it in. This doesn't really seem adequate to me. I don't know if there's a hole on the top of the engine used for this sort of thing to get access to the shaft, but I haven't been able to find anything on this engine that can I could stick a socket or priming tool in. Any idea if there is one, and where it would be?
Any help with these is appreciated. Thanks everyone.
