What was the issue? Did you get it figured out?
Ok tell him to pull the distributor and one of the valve covers. Get a drill, a couple 6" extensions for a 1/4" drive ratchet and a socket that will fit over the oil pump shaft. Tape the socket to the extension, tape the two extensions together and put them in the drill. Put it down the distributor hole onto the oil pump shaft. Now spin the pump until you see oil coming out the top of the head. Put the distributor back in and fire it up. If he doesn't have oil pressure then shut it off and buy a new gauge and check it again.
