Redav72
Have a 1994 3.0. I know that the Rangers of this vintage have an oil pressure sensor that is a switch type rather than variable type. The behavior that I'm seeing is that under particular conditions, mostly cruising at 70mph, I'm seeing a lot of movement on the needle. The usual position of the needle is just over the midway point, when the needle vacillates it drops down the the 1/4 mark. In no circumstance does it leave the normal range and the oil light never comes on.
What am I seeing here? Is it nearing the line where I'm seeing pressure below the threshold but it's just so slight that I get a wavering needle? Is it nothing at all?
