oil pressure gauge 99 4.0
davebar
2001
periodically my oil pressure gauge shows no pressure. file to a few times then reads fine.
Any idea why
The oil pressure sender is an 8 psi SWITCH.
That switch makes your "dummy" gage read midscale.
I suggest you replace the sender. If that doesn't fix it, you may want to plumb a mechanical oil pressure gage into the sender port to see what your oil pressure really is.
The sender is a common failure item.
