- Jan 28, 2014
- Grand Forks, ND
- Manual
Check your wiring by grounding the sensor wire. If the wires are good, the gauge will read normal. If that doesn't help you find the problem, get a mechanical pressure gauge and see if your oil pressure isn't truly low.
Spott
changed all the oil, the pressure switch and filter. My uncle says I have a clogged screen and should take it in. Ugg, I hate this. Cold weather sucks.
