I have a leak that is definitely coming from the bottom of the engine. I just had my valve cover gasket and engine pressure switch replaced (they were thought to be the problem) and the same amount of oil is still dripping on the pavement. It sounds like either the oil pan AND/OR the oil pan gasket is the problem. Your thoughts?
All great information. I had a mechanic look AGAIN and the result...
Rear main oil seal.
I just wish they spotted that first before I spent the money on replacing the valve cover gasket and engine pressure sender. Speaking to many other mechanics, it looks like the labor is the pricey part. The part itself is relatively cheap but the labor (4-6 hours) is the killer. I'm getting quotes between $450-$700. Does that sound about right?
I guess I don't understand what "blowby" is. Can you please explain? Thanks again.
I see. Well I took the advice of removing the oil cap and starting the truck. No smoke was seen at all. Actually, a slight suction what noticed (which I think is a good thing). So does this lead to a bad main oil seal?
