harriw
Hey folks,
Just got a '94 4x4 ext. cab w/ 4.0 and 5spd. about a month ago. Was underneath to replace the fuel filter tonight, and noticed the oil pan was a mess. Looked like oil, but it felt a little bit too thin, and didn't really smell like hot oil does... Oil pressure is normal (per instrument cluster at least), and dipstick shows it's at the high mark (dealer did an oil change 1000 miles ago when I bought it).
Anything else that could be leaking in that general vicinity? Looks like the clutch fluid is where it should be on the reservoir. If it is the oil pan, how bad is it to drop the 4.0 oil pan on a 4x4 and replace the gasket? Can you maneuver it all around the front suspension, or do you have to drop axles and such? Maybe if I jack it up and support from the frame the suspension would sag enough?
It's fairly mess up at least the passenger side too, by the oil filter (though it doesn't look to be coming from the filter). I don't think it's a head gasket, because I had the dealer (my brother-in-law's dealership) run a compression test before I bought it, and it was fine, but maybe a valve cover?
Anyone seen something like this before? I'd appreciate any suggestions on things to look at/for.
Thanks a lot.
-Bill
Thanks a lot.
-Bill
