kenwheeler
My son's '94 3.0 4x4 is leaking oil from the front of the pan. I can see part of the gasket has worked its way out. From what I've read here, this will require some major stuff to replace, most posts suggest removing the entire engine and I read one post where the driver dropped the front axle, yikes.
Is it possible to drop the starter and loosen the pan bolts just enough to push the bad part of the gasket back in? Maybe get some permetx sealant in there?
