Oil Pan Gasket HELP! 4.0L SOHC
hilltopfarm
NW WA
Very frustrated! Please help!!
So i'm trying to get my oil pan gasket put on. This is the upper oil pan, cast aluminum. My truck is a 03' 4.0L SOHC. I ran into these two little tabs that stick down on the rear output shaft side of the gasket. Wondering what to do with these tabs. I'm getting very frustrated, because I wanted to drop the engine in my truck today and this is all that is holding me up. I don't want to get it installed only to find that I have an oil leak on the oil pan, and have to pull it again. Both the shop manual and the Chiltons that I have do not mention these. The pictures of my problem are below... Thanks for any help!!
I had these same tabs on my 5.0L one piece pan gasket, I trimmed them down so they fit snugly in the slots on the main cap and I used silicone on both sides of it to ensure it won't leak for the same reason. I don't want to have to pull it back out because it leaks. Get some good oil resistant silicone and put on there.
Yep that's exactly what I did. Will hopefully start it all up on Saturday.
