- Feb 10, 2022
- New Brunswick Canada
- Manual
Hey all recently I've noticed a ticking when starting my motor when it is cold until it warms up. I've read up online and on a lot of forums it said timing chain tensioners as the seals inside begin to leak and to change them before it is too late. I decided to finally change them today and it wasn't that hard I ended up breaking the thermostat housing so I just changed it entirely along with a new thermostat. Threw on a new serpentine belt as mine was wore and started it up. Ran like a charm and no tick for 5 minutes. Then it ticked when it was warm I began to smell oil so I shut the engine off and it made a terrible rattle when shutting off. Then I kept smelling oil and decided to take a look underneath and just a small puddle was on the floor but when looking up this is what I saw. Could it be the rear main seal? Or by removing the rear tensioner did I mess up a guide or something? I feel like my main seal wouldn't just leak randomly when it wasn't before I changed those parts. My driver side valve cover gasket is leaking a bit but I can't see it leaving all this oil. It continues to drip when it's off and I parked it due to fear of ruining the motor which idek maybe its too late it has 255 000kms on it and I'm not hard on this vehicle and kept up with maintenance. Lately it's been letting me down quite a bit and if the motors done I might have to let it go which I don't want to do. Any suggestions on what is could be or what I messed up? (Yes I primed the Tensioners). Thanks
