nightowl
- Sep 7, 2012
Have a 1988 Ford Ranger pickup truck, 2 wd, 5 spd manual with a 2.0L, 4cyl engine. Would like to know what this means? Could it be valve seals, oil rings? I have also had a tad of blue out the exaust once in a blue moon. So it sounds like the oil rings are going and some cylinder walls are getting glazed.
Have 132,000 kms on engine so far. Will do a compression test and hope this tells all. It could be a big job and not worth the problem. Seems to be coming from the oil filler cap, and vent tube to air filter. changed the pcv, new plugs.
Any help is a appreciated
