LS-300
- Aug 8, 2013
- Automatic
My kid was driving my 02 when he said the oil gauge went nuts. It started to flicker up and down real fast then stopped and looked normal. It apparently a number of times before it dropped down below the lowest point of the gauges range for good. It does raise up a small amount but not even close to being back in the range it's supposed to be. Is it possible to replace just the oil gauge or do I need the entire cluster? Yes the pressure is fine as I hooked up a mechanical gauge I had laying around just to be sure. For my piece of mind I really need to fix this and soon!
