oil filter rubbing motor mount
i have a 1999 ford ranger 4.0 v6 4wd and the oil filter is rubbing the motor mount dose any one know why this is
oil filter
i have a 1999 ford ranger 4.0 v6 motor and the oil filter is rubbing the motor mount dose any one know why might be going on
my oil filter is hitting the motor mount
I'm guessing your filter might be hitting the motor mount.
It may have the wrong filter on it. If I remember right, you should have the Motorcraft FL-820S, which is shorter than the Motorcraft FL-1A.
EDIT: I think the threads are different on the two filters I used in my example (metric vs. sae). They are just used as an example.
My parents '02 Explorer calls for one or the other, it takes the FL-820S but apparently it wasn't a for sure thing and there must have still been some FL-1A 4.0's floating around to still be in the book.
Did the 4.0's have the angle adaptor like the earlier engines? If so it might have rotated on the block...
My 2.8 had something like this from the factory so the filter pointed straight down:
That is interesting that it would have two listed. I thought all of the OHV's were FL-1A, and the SOHC's were FL-820S's. I am pretty sure they are different threads.
OP, If it is rubbing on with the FL-820S, I believe the FL-500S will work as it is a little smaller. I actually remember hearing the aftermarket was going to drop the FL-820S size in favor of the FL-500S. So right now, Motorcraft is the only way you can get that size (or soon to be). The previous owner of my truck put a smaller aftermarket filter on my F150, and it is PUNY!
All OHVs were FL-1A. Some of the early SOHCs were also FL-1A. Roughly MY2001.5 they switched it over to the 820s. The threads are very different. A 1A will spin all day on an 820 adapter and never catch a thread. An 820 being put on a 1A adapter is like throwing a hotdog down a hall way. The holes are very different sizes.
As for the 820/500 compatibility, I have not investigated it myself, but I believe you are correct. The 3.0 DOHC recently switched from an 820 to a 500 (2010 MY I think) and I haven't noticed any difference in threading or position of the filter adapter.
If the filter is rubbing the engine mount, I'd say you have a problem. You need to find and replace the worn out part.
