Oil Filter relocation Kits
DCPerformance
Bel Air, MD
On the swap Im doing, (93 Ranger with a 5.0) what are you guys using for the oil filter relocation. Got a standard trans dapt kit and the adapter clears the steering box but there is not enough room for the fittings to go in it? Figure Id check to see if theres a easy resolution out there first. Thanks
You want a 90degree adapter for the block, if that's not what you have.
I was literally reading the V8 swap article yesterday and reviewing the oil filter relocation part. IIRC they said the normal relocation adapter would fit but theres absolutely no room for hoses.
I think the block fitting is a Trans-Adapt, the filter end is a Wix. I can get numbers but that should get you started. I do wish the filter mount had the outlets out the front...
