chessman21
- Jan 7, 2016
- 1969 f-600hd
- Automatic
Iv got a loose rocker or broke a broke lifter or something and taping that its allways had gets a little louder when oil level gets bottom of hashmark pre-light low,,, 5w30 rear-main drip. I cant take head off but i think i can remover valve cover.. Question is if its in fact a worn rocker or rod will i be able to feel movement or extra movement in the one thats worn? I know what side but i dont know which cylinder. Should i replace the rod to? If a rocker is damaged is it safe to assume the contact spot on rod is worn as well? Can i replace just one rocker and passably one rod? .
