- Sep 18, 2010
- Raleigh, NC
- 2.3L
- Manual
I forgot to ask... Will I need a new oil pan? All of the info surrounding oil pans is kind of fuzzy.
No, the ex oil pan fits both TTB and sala suspension rangers. You will need an oil filter relocation kit with the 90* block adapter...
SVT
Don't waste your money on that. Use your factory 4.0 rubber mount and just fab a plate to bolt to the block. If your not up to it, I can fab you a pair. This also allows you to get over the counter parts if you need a motor mount, unlike the custom mounts everybody else has...
SVT
The way I make em is about as low as it will sit. The block bosses that the mounts bolt to sits 1/4" higher than the top of the rubber 4.0 mounts on the passenger side, the driver side sits about 1.5" above mount (to level the motor). I can fab the plates for you for about $25 a pair (basically covers materials ) plus shipping...
SVT
