Odometer
Cadiz,ky
Got some 32 on 15s I know bigger set of wheels like to mess with the odometer it keeps going up is there a way to sort of fix it 1985 ranger?
I'm not as familiar with the first gen sizes, so you would have to either google up your original size or look at your door sticker, then use one of these calculators to figure out which count tooth of a new gear you need on the speedo cable:
Figure out what speedometer gear you have (color works, they're color coded) going into the transmission at the end of the cable and assuming you haven't regeared the axles you will likely need to get a replacement with a couple less teeth.
