Odd turn signal problem
canucker
No Fords.....ye
2005 mazda b3000 Dual Sport Auto
When ever i turn on my signals they will flash for about 1-5 times then just go out. it does not matter what side (right left). im at odds as too what could be causing this issue. i though maybe a relay but cant find one listed in the owners manual. what else could it be.
thanks Sean
If you turn off the signal and restart will it go another 1-5 times?
Check trailer connection wires, especially if you have never used them.
Replace Flasher, they are cheap.
Probably the flasher.
Thanks for the replys guys. where do i find the flasher. i know i sound like a noob but i looked in the owners manual and cant find the location.
-noob
Should be under the dash near the steering column, square plastic box/relay.
Turn on the key, and then turn on the turn signal, repeat as needed, you should be able to pin point it by sound and then feel.
I would buy a replacement first so you know what to look for.
