90longbed
every so often I have an issue with the turn signals......when stopped with foot on the brake the left turn signal does not flash...... will start flashing again when you start moving, you can switch to the right turn signal and it works fine when stopped and the left still does not flash after you flip back to it.....then it will work fine again on the next left turn.... happens about once a month, both times it was sunny out.....was a mechanic for 12 years and never seen this issue before..... have checked bulbs and fuses
