After I built my coilover hoops I found I couldnt use the stock master with the brake lines coming out the side facing the fender due to clearance issues. Somebody told me to get a new master off I believe a 88 STX cause the brake lines went in on the other side facing the motor.
I have the new master with the fittings on the side facing the motor solving my clearance issues but the rear port uses a different fitting and Im not sure what it is. The front port is normal and takes a 3/16 flared fitting,however the rear port has no seat for a brake line to seal against and appears to be a straight thread.It is not a NPT pipe thread.
Anyone have any idea what fitting goes into this port?
