Help me dive into these codes before I start throwing parts at it. 94 Mazda B4000.
Driving: Part throttle cruise is surging almost like a misfire but not rough-running. Almost as if you are cycling the AC compressor on and off rapidly or instantly going from 40-60% throttle about 5 times per second. I can make it stop by stabbing the throttle to WOT for a second. (this one is pretty obvious once you look at the codes).
I have suspected that the catalyst may be partly clogged. My main reason for thinking this is that it's has always seemed to not live up to its whopping 160-hp potential coupled with two other symptoms; a ridiculously quiet exhaust and the little reference hose keeps blowing off the EGR valve.
This brings me to the codes.
114 | Out of range voltage air change temperature sensor (ACT) | Normal operating temp not reached |
116 | Out of range Engine coolant temperature sensor (ECT) | Normal operating temp not reached |
335 | Electronic pressure transducer (EPT)/differential pressure feedback exhaust (DPFE) sensor |
522 | Neutral/drive switch (NDS) |
Then, I get a random string of codes that A) don't make sense, and B) some don't exist in the EEC code database.
117 | Low voltage Engine coolant temperature sensor (ECT) | Normal operating temp not reached |
643 (doesn't exist)
343 (doesn't exist)
176 | Lambda sensor (left) too lean |
543 | Fuel pump (FP) circuit failure |
I get the EGR code. That would explain my first symptom above. Question is (before I throw a part at it), could a clogged cat be forcing the valve open/closed with the excessive backpressure at the valve?
The claims that it's not getting up to operating temperature are BS. 195 stat that opens/closes, and my laser thermometer verified 198 at the thermostat neck. That suggests a cascade of sensor failures all at once, which I don't think would likely happen.
The Neutral/Drive switch makes me chuckle because it's a manual transmission.
Fuel pressure is easy to test... provided there isn't an intermittent electrical failure that would lead to a false good reading. Recent fuel filter, fuel pump relay, and reman injectors 5000 miles ago. No raw fuel in the FPR hose.
Can you folks make sense of my EEC-IV alphabet soup?
