OBD1 Codes?
tj37
I ran the actron code scanner on my ranger. It flashes lights to tell you the codes. I cannot distinguish when one code ends and another begins. I have taken a video after it had already flashed the engine id (3 times = 6-cyl). Can someone take a look and help me out with the numbers?
Can I upload a video to this site?
Thanks,
TJ
Three digit codes. Each digit is a count of pulses from 1 to 9, then a pause, then the next digit. After the first code is displayed, the next (if present) is displayed and the process continues until all have been flashed. Then the entire set is repeated so you can verify that you copied them accurately. If you're doing KOEO codes, there's a pause, a single flash, a pause, and then the continuous memory codes are displayed in the same manner.
For example...
1-1-1,,1-1-1
Is a 111 pass code.
111-11-1111,,111-11-1111
Is 324
111-11-1111,11-111-11,,111-11-1111,11-111-11
Is 324,232
Hope that helps.
