Woodtroll
- Aug 4, 2008
- Automatic
Hello, folks!
I am having trouble with my '86 Ranger with the 2.3L multi-port EFI. Several weeks ago, I started noticing a "hitch" at highway speed, then it stumbled on me a time or two; sometimes it would stumble and then backfire, which makes me think it is getting fuel but losing fire. I replaced the TFI ignition module, since that has given me problems before. The problem got a little more frequent, so I replaced the fuel filter and dropped the tank, looking for water, then in the process cracked the rusty fuel discharge tubing, so had to put a new fuel pump/ sending unit in it.
Today I was looking for wiring harness shorts, etc., started the truck and let it run, turned my back on it, and it just quit. Crank, crank, crank, would not start. I pushed the fuel rail Schraeder valve to see if it had fuel, and just a very brief spurt (less than 1/2 second) came out. Pulled #1 ignition wire and put an old plug on it, jumped the starter solenoid, and it fired right up on three cylinders!
Shut it down and restarted it several times without a hitch. Now I am stumped...
There are connections on the passenger side fender that look as if they may be diagnostic hook-ups- are they?
Any ideas about what could be causing my problem? I could still have a bad high-pressure fuel pump, or maybe the stator assembly could be bad? I put a fuel gauge on the rail, and it ran about 35-40 lbs. the whole time, but it never gave problems while the gauge was attached.
Any input would be very much appreciated! Take care,
Regan
Regan
