cp2295
- Jul 25, 2013
- Washougal, wa
- My credo
- If you ain't first you're last
So I was thinking about swapping a 4.0 into the bronco, my 2.9 is tired and burning oil and doesn’t run quite right. I personally like obd2 much better than obd1. I also like MAF sensors vs MAP sensors. If I were to get a complete engine harness, and possibly a body harness from a ranger how difficult might it be? I’m pretty good at wiring, have rewired a couple of harnesses. I figure the ecu only needs so many powers and grounds to function properly so if I read the diagram and figured that out I should be okay. Then run the obd2 port up under the dash. Wouldn’t be too concerned about engine codes as I don’t have to pass emmisions in this old truck. Only engine codes I could think of getting anyways are a post cat o2 sensor (since I wouldn’t run one) and maybe a speedo sensor code since I’d just use the Broncos cable driven speedo. Also, would my stock gauges work or are the values different for the 4.0s sensors...? Might even be able to put the 2.9s dash sensors onto the 4.0 engine. Another issue I can think of is fuel pressure, would i need to swap an in tank fuel pump into the bronco or would I be okay if I got a 4.0 with a return type fuel system? And just used system that’s in the rig now.
The 4.0 should just bolt into place am I wrong? Probably going to swap an m5r1 for the fm145 that is on its way out anyways too.
Anything else anyone can think of let me know appreciate it thanks.
