O2 sensors
mht95ranger
Ma/NH border
Ok guys, I have a problem with my truck again. I have cel and pulled the codes. 135 141 155. I know that the are the o2 sensors heat circuit faults but what is the chance all 3 o2 sensors went bad? Looked on line and found that newer rangers had a fuse for the heated o2's. Can't find anything like that for my 95??
Anyone have any ideas for me to check? Once it warms up a little I will climb under there and look at the harness.
Thanks for the help, David
You're correct thinking all three 02 sensors don't go bad at once. Just out of curiosity:
  • Has the MPG drastically changed?
  • Does the Ranger belch black smoke?
  • Is there a velvety black residue around the inside of the tailpipe?
  • Have you put a voltmeter on any of the 02 senors to see what they're reading?
Mileage has not been good but I thought it was because of the snow and use of 4x4.
No black smoke
a lot of stuff in the tailpipe
not yet on the volt meter again because of the snow. What am I looking for with the volt meter?
