v8318cid
Ok, I'm trying to sort out a problem with the O2 sensor on my 92 2.3L. I've chased down all the problem codes in the system and eliminated all but the 172 code (O2 lean). I've checked for vacuum leaks, replaced the throttle body and upper-to-lower intake gaskets, and replaced the EGR valve and gasket. I still get a 172 code regardless. Every now and then the MIL will not turn on, but its rare. Always turns on after about 1 mile of driving. Also get the same code if I disconnect the O2 sensor, although that isn't really unexpected. The engine runs the same either with or without the sensor. The wiring harness looks good. I've also checked the Tech page for troubleshooting the sensor, but I cannot figure out the exact procedure for checking the wiring. The diag page talks about a picture or diagram of how to properly hook up a volt meter, but there doesn't appear to be a link or a picture to check. Any ideas? By the way, does anyone know if the ECU uses the speed sensor just above the speedo cable to control engine performance or is that sensor something to do with the RABS controls? Thanks.
